FutureGarageForum.com • View topic - Future Garage Drum Patterns!
Postby JimmJimm » Sun Feb 06, 2011 11:21 pm
New to Future garage and I don't kno much about the drum patterns, anyone got sick beats? :D
JimmJimm
Re: Future Garage Drum Patterns!
Postby MileZ » Mon Feb 07, 2011 5:31 pm
Ehmm nope. What program do you use?
MileZ
Postby donga » Tue Feb 08, 2011 2:32 pm
listen, be inspired, build yr own
donga
Postby JimmJimm » Tue Feb 08, 2011 4:52 pm
I would but I dont kno the rules! I dont kno much about 4/4 beats like...
JimmJimm
Postby blnd! » Tue Feb 08, 2011 5:41 pm
JimmJimm wrote:I would but I dont kno the rules! I dont kno much about 4/4 beats like...
dis game has no rules
swing and skip meta-masterclass thread:
viewtopic.php?f=2&t=98
Postby JimmJimm » Tue Feb 08, 2011 7:07 pm
I use fl and reason btw
JimmJimm
Postby JimmJimm » Tue Feb 08, 2011 7:10 pm
http://www.youtube.com/watch?v=_Zta2Xbis6E
Does anyone kno this pattern? Serious beat and Ive been messin around all day still cant get it!
JimmJimm
Postby Stealth Elf » Tue Feb 08, 2011 11:53 pm
To make something like that takes a LOT of practice man. Seriously just work at it night and day and eventually you'll get there.
Everyone wants a quick fix these days, you aint gonna be making sick tunes for a long time. That's just the way it is.
Stealth Elf
Postby Josif » Wed Feb 09, 2011 8:37 am
be original, make something that you just like the sound of? doesn't matter if its not a typical "garage" beat. if everyone wanted to copy someone else there would never be progression or unique styles or sounds?
Josif
Postby blnd! » Wed Feb 09, 2011 4:08 pm
JimmJimm wrote:http://www.youtube.com/watch?v=_Zta2Xbis6E
its a pretty simple swingy 2-step beat, (i can draw it when i get home), just cut di drumloop n try to rebulit it, n after u can modify it n/or write yr own drums, but as i said der aint no rules in dis game
useful threads:
viewtopic.php?f=2&t=1329
viewtopic.php?f=2&t=1499
Postby gnome » Wed Feb 09, 2011 7:53 pm
Consume as much of the sound as you can. That way you will build it a lot easier.
gnome
Postby Stealth Elf » Wed Feb 09, 2011 10:01 pm
useful threads:
The actual pattern isn't too complex but the choice of samples and processing on them is really sweet. Something I kinda suck at really.
Stealth Elf
Postby djbmc » Thu Feb 10, 2011 8:04 am
First off get a kick drum on beat 1 and get the snares down, they're in the same place every time and are dead on the strong beats, then put a hi hat on the off beats. Getting the strongest parts of the beat down first will help you get a feel for where the rest of it should go. The rest is a mixture of swung hits and slightly behind the beat programming, you also need the right type of sounds, normally a shaker, a few hi hats sounds (to keep things a bit varied) and a few percussion hits, they need to be pretty short and snappy to stop the tails of each sample getting in the way of the next instance of that sound (or any other).
djbmc
Postby MileZ » Fri Feb 11, 2011 3:22 pm
JimmJimm wrote:I use fl and reason btw
For Reason; add shuffle! LOTS!
MileZ
Postby Stealth Elf » Fri Feb 11, 2011 7:38 pm
By the way, if OP is still having trouble with this then I'd be happy to send you some midi files of my better garage beats. I'm no master but it might give you a better idea of how to start putting things together.
Stealth Elf
Next
